Need help to ID this HUGE mikuni
Offered to help somebody with their Yamaha Riva 125, and somebody before them had slapped this giant mikuni on it and didnt tune it, and I may need jets. Can anybody help ID it? It doesnt have a size or model on it, and it might even be a knockoff....unmarked jets. It's a 4 stroke carb, it has a butterfly valve and a diaphragm operated slide.
Re: Need help to ID this HUGE mikuni
It looks like it might be a Generic version of the stock carb. Like the cheap ones you buy on ebay. The biggest difference I see is that it has a manual choke rather than the stock electric choke. i would measure the diameter and thread of the jets and see if mikuni jets are the same.
I didnt think to check, but now that you mention it I do recall the main jet being about the same size as 5mm dellorto.
This carb is much bigger than I think the stock carb was (dont have the stock carb), somebody had cut a hole in the plastic fender so the bowl would fit.
Want to reply to this thread?
