Re: work arounds
♣Slew Foot♣ /
Now that was basic if you want to get really really artsy I used a torsion spring from a window shade then I attached metal pole with a ball end and it was wrapped with copper wire that I wove into what they would call a rodian coil and then I used an oblong shaped clip of metal a Spoke a troll doll and several magnets another Thomas Drive with a magnet on it Off Saks donut a batavus clutch piece a Tomas break chain tensioner and an old mixing board and the troll doll simulates perpetual motion from the ground current oscillation using what's known as the tennis racket affect whereas if you spin-off a wing nut in space it will rotate so many times as its traveling on its axis and then it will flip and it will continue to do this as long as it's spinning along that axis now technically I guess this is not perpetual motion cuz the magnets will wear out and the ground oscillation is not an actual effect however I am running the right Channel off the mixer into the negative ground and it kind of makes the troll dance to the music having had all this time because of the three accidents I was in in the last 3 years it really cut into my riding time and since I can't really work on the mopeds I got to do something as a focus exercise if it wasn't this I'd be building model ships or something... (edited)
