> Stephen Keller Wrote:
> ^ I've run 50/50 forever, and last winter when the actual temp was -26F
> all three cars started and came to temp fine, I think 50/50 is good to
> -34...if it's that cold I'm not bothering with any of my vehicles! ;) If
> I had some $ to waste I would take the no name stuff and say Prestone,
> (what I have used for yrs) to a lab down on the U and have it analyzed,
> I would bet they are the same stuff. Prestone used to make a water-pump
> lube back in the day, wonder if that is still a thing? Not seen it in a
> while. To all who mentioned it, when using and mixing my own coolant, I
> have always used distilled water. Thanks for the opinions, and for
> weighing in.
No, they aren't the same stuff,just close. Like gasoline, the additives make the difference. Antifreeze gets weak and the PH changes. I change the backhoe's antifreeze every 5 or 6 years even though I put few hours on it. I run 60-65% antifreeze no matter what.
We've seen 38 below zero in Southern Ohio and I've seen antifreeze turn to slush in the radiators.
I only use Motorcraft antifreeze in the 2 Lincoln LSes and the Mustang I own,because of the plastic parts and Ford's recommendation.
I put the old green stuff in the Aerostar and F-250.
