Re: Honda Rebel
Norris Hall /
> Born to be WillD Wrote:
> havent been able to get back to it, it's at our shop and I really only
> get time to go there on tuesdays. it wont flow even if the drain bolt's
> out so i think it's not the vent. I was flipping it up and down and just
> blowing in the fuel line - it'd flow until i put the bowl on. So maybe
> it was upside down, but there's like the little pocket for the float
> needle to go in, hang it in that and drop it into the hole, i don't see
> how that'd work upsidedown. but havent checked since you suggested it.
> the carb was pretty gummy, I think the little tabs that would help pull
> the float needle down, one's bent so the needles' just sticking. gonna
> tryn clean it better and see if a new needle works, and then if not try
> a new float.
> thanks again
No prob, It looks like a cool bike and I'm just throwing ideas out there. You are right about the needle and float assembly for sure. If the two are put together properly and installed in the carb then the float would have to be in right side up. I just know that if you are assembling the carb upside down on the bench it would be possible to drop the needle in the seat and then put the float down on top of the needle which of course would be the wrong way to do it but that would make it possible to install the float upside down. See what I am saying? It was just a thought and it sounds like it is probably something else weird going on. Good luck with it though.
  Honda RebelTopic by: Moped Lar (OFMC) Moped Lar (OFMC) 02/12/20 12:19PM
  Re: Honda RebelRe: Jimmy Cincinnati Jimmy Cincinnati 02/12/20 12:29PM
  Re: Honda RebelRe: Moped Lar (OFMC) Moped Lar (OFMC) 02/12/20 12:36PM
  Re: Honda RebelRe: Satan 666 Satan 666 02/12/20 01:11PM
  Re: Honda RebelRe: Jimmy Cincinnati Jimmy Cincinnati 02/12/20 01:42PM
  Re: Honda RebelRe: Chris Szuba Chris Szuba 02/12/20 01:51PM
  Re: Honda RebelRe: live ɘvil live ɘvil 02/12/20 02:20PM
  Re: Honda RebelRe: Stephen Keller Stephen Keller 02/12/20 02:39PM
  Re: Honda RebelRe: Chris Szuba Chris Szuba 02/13/20 06:35AM
  Re: Honda RebelRe: Stephen Keller Stephen Keller 02/13/20 01:44PM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/12/20 02:30PM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/12/20 02:31PM
  Re: Honda RebelRe: Don Ohio Don Ohio 02/12/20 04:50PM
  Re: Honda RebelRe: Born to be WillD Born to be WillD 02/12/20 05:41PM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/12/20 07:44PM
  Re: Honda RebelRe: Born to be WillD Born to be WillD 02/13/20 09:44AM
  Re: Honda RebelRe: The Dude The Dude 02/13/20 09:43AM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/13/20 10:16AM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/13/20 02:51PM
  Re: Honda RebelRe: Stephen Keller Stephen Keller 02/13/20 03:10PM
  Re: Honda RebelRe: Satan 666 Satan 666 02/13/20 04:31PM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/13/20 05:41PM
  Re: Honda RebelRe: Norris Hall Norris Hall 02/15/20 11:28PM
  Re: Honda RebelRe: Born to be WillD Born to be WillD 02/19/20 12:10PM
  Re: Honda RebelRe: Norris Hall Norris Hall 02/19/20 07:53PM
  Re: Honda RebelRe: Norris Hall Norris Hall 02/19/20 08:01PM
  Re: Honda RebelRe: Norris Hall Norris Hall 02/19/20 08:03PM
  Re: Honda RebelRe: Norris Hall Norris Hall 02/20/20 09:53AM
  Re: Honda RebelRe: Norris Hall Norris Hall 02/16/20 01:58PM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/16/20 04:08PM
  Re: Honda RebelRe: Norris Hall Norris Hall 02/16/20 04:22PM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/19/20 01:45PM
  Re: Honda RebelRe: Born to be WillD Born to be WillD 02/20/20 12:14PM
  Re: Honda RebelRe: Norris Hall Norris Hall 02/20/20 03:23PM
  Re: Honda RebelRe: Norris Hall Norris Hall 02/19/20 08:20PM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/20/20 05:23AM
  Re: Honda RebelRe: Norris Hall Norris Hall 02/20/20 09:49AM
  Re: Honda RebelRe: Born to be WillD Born to be WillD 02/20/20 12:16PM
  Re: Honda RebelRe: Norris Hall Norris Hall 02/21/20 10:24AM
  Re: Honda RebelRe: Born to be WillD Born to be WillD 02/21/20 11:02AM
  Re: Honda RebelRe: Norris Hall Norris Hall 02/21/20 11:56AM
  Re: Honda RebelRe: Stephen Keller Stephen Keller 02/22/20 08:30PM
  Re: Honda RebelRe: live ɘvil live ɘvil 02/21/20 12:08PM
  Re: Honda RebelRe: Born to be WillD Born to be WillD 02/21/20 03:31PM
  Re: Honda RebelRe: live ɘvil live ɘvil 02/21/20 05:23PM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/22/20 07:37PM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/22/20 09:15PM
  Re: Honda RebelRe: Satan 666 Satan 666 03/03/20 09:21PM
  Re: Honda RebelRe: Satan 666 Satan 666 03/03/20 09:25PM
  Re: Honda RebelRe: live ɘvil live ɘvil 03/03/20 10:34PM
  Re: Honda RebelRe: Satan 666 Satan 666 03/04/20 07:02AM
  Re: Honda RebelRe: ID OD ID OD 03/04/20 07:07AM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/22/20 09:32PM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/23/20 03:36PM
  Re: Honda RebelRe: Moped Lar (OFMC) Moped Lar (OFMC) 02/24/20 03:22PM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/24/20 07:22PM
  Re: Honda RebelRe: live ɘvil live ɘvil 02/24/20 09:29PM
  Re: Honda RebelRe: Moped Lar (OFMC) Moped Lar (OFMC) 02/25/20 07:17AM
  Re: Honda RebelRe: live ɘvil live ɘvil 02/25/20 09:39AM
  Re: Honda RebelRe: Born to be WillD Born to be WillD 02/26/20 09:44AM
  Re: Honda RebelRe: live ɘvil live ɘvil 02/26/20 10:48AM
  Re: Honda RebelRe: Born to be WillD Born to be WillD 02/26/20 10:02AM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 02/26/20 01:37PM
  Re: Honda RebelRe: Born to be WillD Born to be WillD 03/03/20 07:32PM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 03/03/20 08:47PM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 03/04/20 10:51AM
  Re: Honda RebelRe: Full Tuck Full Tuck 03/24/20 08:08PM
  Re: Honda RebelRe: Moped Lar (OFMC) Moped Lar (OFMC) 03/25/20 11:10AM
  Re: Honda RebelRe: Jax Rhapsody Jax Rhapsody 04/06/20 01:57AM
  Re: Honda RebelRe: Pushrod Fifty Pushrod Fifty 04/06/20 06:32AM
  Re: Honda RebelRe: Ernie Wan Ernie Wan 04/06/20 11:06AM
  Re: Honda RebelRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/06/20 11:22AM
  Re: Honda RebelRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/09/20 10:03AM
  Re: Honda RebelRe: Born to be WillD Born to be WillD 04/10/20 12:01PM
  Re: Honda RebelRe: Satan 666 Satan 666 04/09/20 10:17AM
