I don't speak Hindi but you think even if its 4 stroke without ring lube it would've seized.
If you are ever out of fuel and got bangsite
Walk it home anyway.
It must be a 2t with oil injection
Cryptic wizdow topic header. ...
Acetylene, hunh.
Darndest thang
One for the endtimes..
This has a a pretty high risk factor at wot if the power band hits the boost bottle. ...
I did find antique moped headlights that ran on bangsite.
Bethlehem Pa is the proud birthplace of the Conestoga cannon co. Which is now big bang cannons.
But if you ever seen a Sachs Bing 54 for the rear of a rotax airplane motor it has this NO2 port into the float bowl adding a measured dose for high altitude. If you hooked acetylene to it would it be the bomb?
Whatch it kid you'll shoot yer piston out.
No you got that backwards, running acetylene instead of Nitrous oxide would make a airplane motor run rich possibly foul out the plug but it would not make it into a bomb
you guys are silly if you think im dumb enough to google "BANG SITE"
Hydrogen generator out of a pressure cooker - cool
People just miss the awesomeness.
But what would happen if you introduced it to WOT. As like a supplemental boost.
I seen what acetylene does at 1 to one ratio with air.
Take a gallon milk jug putty in a nice leader fuse. 15 seconds . at 1.1 its like 2 sticks of dynamite.
Don’t think you’d want to add more fuel for boost.
Better to introduce more oxygen and more of the gas you’re already working with.
Well, this is why we have a wonderful repair section for the adventurous. LOL!
