> Pops Peds Wrote:
> > live ɘvil Wrote:
> > > Pops Peds Wrote:
> > > Evil just to give you an insite....the impact hammer inside makes
> the
> > > rattle without a loose socket...thats what impacts do.....hahaha
> loose
> > > socket lolololl. Hahahaaa
> > You obviously have never used two hammers at once dumb ass.
> The more you try to convince yourself you're right the dumber you
> get....when you hammer on the corner of a nut or bolt with a loose
> socket it is going to round the corners..... loose socket hahahaha
> lololololollllllllll by the way ....once you round the corners it is
> that much more hard to get loose...dumbass
You have no clue because you've never tried it. It never occurred to you to think outside the box. You are speaking on your opinion AGAIN. I stated what I have learned from experience. Its worked more than once.
Again, the next time an impact fails to remove a stubborn bolt, grab the next size larger socket (6 point). That would be 1/16 or 1mm larger. No it will not round the head off. If it does then you shouldn't of been using an impact anyway. Otherwise just get cut it off.
