> Seth B Wrote:
> Socket was just worn larger. Steel wears off quick when you use the same
> socket day after day, so yeah an old, worn socket would be about 1-9/16,
> loose as a goose. When they finally start slipping on the nuts, we’d
> throw it away. New socket was tight, hard to get on the nut, and
> wouldn’t break em loose as well. Simple physics.
> One inch impact running at 145psi. Man tools. For big nuts.
Are you learning yet pOpSoHiO?? I run 175psi in my 80 gallon compressor.
