Re: WTF GM?
Service history found today on a car, had to get a picture of the write up lmfao 🤣
Re: WTF GM?
> Don Ohio Wrote:
> Just an over-engineered piece of junk that should have had the oil
> changed long ago.
If either were true they still have absolutely nothing to do with what actually happened.
"Ford's the best" LMAO!
Re: WTF GM?
FORD'S the best................then there's the rest.
Re: WTF GM?
Fords are for suckers, as proven by the numbnut from ohio.
Re: WTF GM?
You danced around everything I mentioned. Best for you to stick to lawn mowers.
Re: WTF GM?
> up lmfao 🤣
Yeah that probably happened in Arkansas. The armpit of america
Re: WTF GM?
Anyway, the Mercedes lives! Cleaned out the shards of belt that plugged up the oil pick up and got it all back together. Lifters were noisy for a little while until the new oil got circulated into them. Runs better than before believe or not. Found the cause of a recent clunking noise that had just started before the serpentine belt fiasco. Not bad for 180,000 miles. Fuck you DoNoHiO and your ford junk!
Re: WTF GM?
Ford's the BEST.....then there's the rest. So what kind of a cheap,junky lil' motor mount is that?
Must've come from the lowest bidder.LOL!
Re: WTF GM?
^ Why are you always so negative? Seek help, as I said before, you of all people better hope religion is bullshit, as in spite of what you think, you are about as far from what it wants as you can get. If there is a god it sure does not advocate arrogance, and self importance, things you exude at every opportunity. You are not the chosen one, just a relic from a time where people knew no better. Wake up to the new reality, move forward, accept that people different from yourself have about as much chance at being right as you do. No one is better than anyone else. You are so tiresome sometimes! That said I have good luck with Fords too, but the old ones, rear drive, I have a "new" one 2006, but it is still v8 rwd, built like a tank, and runs like a swiss watch. Keep your religion and self congratulatory remarks to yourself and you may get less shit shoveled your way.
Re: WTF GM?
Keep your anti-religion remarks to yourself and you might make a good boy someday,Stephen.
I'm negative when I see cheap parts. That's a sorry excuse for a motor mount. Tell it like it is.
Re: WTF GM?
Re: WTF GM?
punkrock randy /
Poor Jerry’s probably stuck on the side of the road somewhere, blown head gasket. Fuckin =DuMbOhiO sucks as a “friend”
Re: WTF GM?
https://www.caranddriver.com/reviews/a32741897/tested-2000-mercedes-benz-ml55-amg/
Re: WTF GM?
You can be banned for repetitively spouting off religious quotes brick head. Not the other way around.
You dont know your ass from a hole in the ground. You've shown that every time you open your mouth. Youre a no-nothing washed-up old privileged white hobbyist. That motor mount lasted 180,000 miles and 20 years. That's about the time it takes to bury one of your fords because its worn out. Learn to read and you wont look so stupid. (edited)
Re: WTF GM?
punkrock randy /
“Just poke it with a Q-tip and live yer life walking beaches and spending money.”
-=DumbOhioFloFaciSt-
Re: WTF GM?
Ya, Jerry could of had his coolant topped off at any jiffy lube on any corner.
Re: WTF GM?
If Ida let Jerry drive home, he mighta lost the engine. MOST people just don't care enough. IF you care, you'll do the job correctly.
Re: WTF GM?
You fail by your own words! You didnt do the job correctly. Topping off the coolant does not solve the problem as to where it went. Parts changer.
