> Bas Autowas Wrote:
> Gonna install this puppy today, 25hp 3 cylinder.
Nice, what kind of van do you have?
Bas can't keep a job so he can't afford to own a ride or an outboard ...seems at the first of the thread he thought outboards were a total waste of time..lppks like he back pedles to fit the need...
Your getting delusional again soppy, take your meds.
> Bas Autowas Wrote:
> Johnson 2 strokes are also a great way to waste gas.
Wonder what this means..
That Johnson two strokes are a waste of gas, as you can read. On outboards 4 stroke is the way to go.
Meh. They are nice but cost alot, are very heavy, not so simple to work on. I prefer a nice old fast twin over a four stroke anyday. I like four strokes on larger boats that are gonna stay on the boat but if you got to remove it then the two stroke is the best. Sucks trying to muscle those big ass heavy guys.
I picked up another 7.5hp so I jusr swapped the nicer (but not perfect) propeller onto mine and I shaved down all three blades of the chewed up propeller to match a template of the smallest blade equally until I get around to building them back up. I would still be interested in a nice Gamefisher 7.5 prompt as a spare if one ever turns up.
Now what I need is a Gamefisher (Tanaka) 3.0 replacement carb because this one was destroyed in shipping
Yeah i get that, but i really enjoy the lack of noise on a 4 stroke, also fuel efficiency. Today we used only 6 or 7 litres on a 5 hour trip. With a 25hp two stroke it would be about triple that. In the summer we often just go around the canals in the old city centre (5mph speed limit) and with a 4 stroke you don't even hear the engine at that speed.
So for me i'll never get a 2 stroke outboard again, but if you want to be able to carry it and you don't mind the noise, shure buy a 2 stroke outboard.
Small 2 stroke singles are great for dingys, easy to carry. They arent that loud compared to a 4t single. Gas consumption about the same. For a larger engine, a 2t is a bitch to go slow with in a no wake zone.
I had a 150 hp 6 cylinder 2t yamaha. Try feeding that hungry beast. The large four strokes are very quiet. I used to work for a marine construction outfit and we has several boats with hondas. We had a 225 honda on one of them and I would constantly turn the key and grind the starter because you could barely hear it running.
Here we go again.
These are both running 3hp 50cc cylinders with 25mm unrestricted exhaust headers and the intakes are 16mm ID.
I don't plan to do any porting but the carbs are only 14mm venturi's so there's easily enough room to go to 15 maybe even 16 without touching the top of the atomizer.
They are already jetted rich so I think I can get another 0.2/0.3hp just opening the carb.
I was gonna say, those tanakas are the base of many cheap shitty china carb. you can also use an SHA
> Monti S Wrote:
> Here we go again.
> opening the carb.
Why not try and fit an expansion chamber on one of those bad boys. Be a fun project.
