really you might just not have a good tank vent. try also gravity feeding the carb. you can suck on the vacuum line (it's never got gas in it, don't worry. this is a genuine suggestion too, not some "bleach" joke) and that will let gas flow. you can also loosen the screw on the line under the carb to drain the gas out of the carb - check that to make sure gas flows when you suck on the vacuum line (thus artificially opening the petal valve) and also make sure the gas that comes out doesn't have water in it (it'd separate/float blobs in the gas)
Re: Scooter problem???????
