Need Honda Elite 250 dimensions, height/length
Does anybody have an Elite 250 that can get me some specific measurements? I plan on making a long drive to pick one up, and I need to make sure it will fit in my Honda Element. The rear opening is just over 40" high at the mouth, and gets taller inside at just over 45". I need a height measurement at the tallest point that isn't the windshield, which is the top of the dash I think. If it's close, deflating the front tire and compressing the forks can help to get it inside. Or maybe the front plastic can be removed? Not sure, never had one in front of me. Length probably won't be an issue. TIA
(edited)
Re: Need Honda Elite 250 dimensions, height/length
Pretty sure it’ll fit if you lean it and remove mirrors. I don’t have any ch250s any more but I had a bunch over the years.
Too much power to be on 10inch rims. Got mine to 78mph once and it was terrifying
If it is too tall you can remove the tires to transport it
Moped Lar (OFMC) /
Front wheel easy to remove. Rear wheel removal requires removal of the exhaust first.
I have a Honda Element and I used to own a CH250. I can't see it fitting without removing stuff.
> Pops Peds Wrote:
> If it is too tall you can remove the tires to transport it (edited)
> exhaust first.
Rear would be less likely to need to be removed ,but you do what you.have to do if needed.i was just.giving them options if needed (edited)
> exhaust first.
Good to know. I have a hitch carrier rated for 400lbs, an elite 250 is 280lbs or so, I think it would work instead of trying to stuff it inside.
> > exhaust first.
> fitting
> inside.
Sounds like a plan
If you pulled the seats out of the Element, (cool car btw) I think you could get it in there tilted, but if you have a hitch carrier I would try that first, congrats on getting a super cool bike in the ch-250!
punkrock randy /
I can measure in the morning if u still need? Sry, gotta order wings and p’za cause everyone’s yelling at me and it’s getting dark.
Mmmmmmmmmmm pizza, it's quiet here (by design) but pizza is always in order!
