Honda MB5 - 6 speed transmission / heavy clutch conversion
Jimmy Cincinnati /
Selling a 1981 Honda CR80 transmission. This is a 6 speed transmission that will directly bolt into your honda MB5's transmission without case modification. In addition to adding a 6th gear to your MB5 you also get a better clutch out of this motor. I have done one of these builds in the past with little issue (use the MB5 cases and Mb5 balancing gear with these internals). $100 shipped east coast or $115 shipped west coast. Or $80 picked up in Cincinnati Ohio.
When your done with the conversion pop these engine halfs & crankshaft up on ebay and get some of your money back. The engine cases are in nice shape (no chain slap). Thanks! (edited)
Re: Honda MB5 - 6 speed transmission / heavy clutch conversion
any idea what the ratios are?
nvm found it
Jimmy Cincinnati /
bump
buy it before it hits ebay!
Jimmy Cincinnati /
SOLD! Thanks
Nikoletta Pál /
Only the 1980-82 tranny fit the mb?
Jimmy Cincinnati /
I believe its only 80-82. Ive swapped the trannies twice using that year range. Its actually pretty straight forward of a swap and gives a good excuse to freshly seal up your motor.
