FS: 1977 Puch Maxi 70cc (DE)
Tyler Durphine /
Fully rebuilt 1977 2hp Puch Maxi moped w/ 70cc kit. Starts on first kick, cruises up to 50mph.
Registered in VT with tag. Includes 2 gas cans, extra gaskets, cables, oil, spark plugs, transmission fluid and Puch decals.
List of some of the build parts most from Treats:
70cc treat KIT
70cc hi hi compression head
Tecno BOSS performance pipe
5 dellorto main jets - 80s range
5 dellorto main jets - 90s range
Dellorto PHBG 21mm carburetor
Malossi E12 air filter
19mm PHBG piston port intake
Engine bearings and seals
BLUE hi tension clutch springs
E50 case allen bolts set
Super stuffy racer crankshaft
Domino grips
Giuliari black TWO SEATER
Passenger pegs
Rear shocks
Gold chain for both sides
Brake pads
Magura brake lever bolts
All Cables
Tubes and tires (sava MC1)
Spark plug and spark plug boot
Center stand kit
EBR BLACK maxi forks WITH stabilizer + reinforced top plate
MLM Reinforced swing arm
Forks headset bearing set
Headlight
Petock, fuel line, and filter
17 tooth front
