WTB Sachs 504 Crank
Looking for a Sachs 504 crank or perhaps a whole 504/505 bottom end! Whaddaya got!
Need shipped to 37216 (Nashville). Thanks.
Re: WTB Sachs 504 Crank
Bump -
I need a 504 crank/flywheel/woodruff key
OR
A complete 504 bottom end.
No longer looking for 505 bottom end, which will not fit on a Sachs Westlake.
Thank you.
Sorry just had to leave this comment so I could follow the post. /bump!
Get a 505 d crank and a derbi motoplat flywheel. Time it with no key and enjoy 2mm of stroke on your wimpy 504.
To my knowledge, It has been debunked that there is a crank with a longer stroke (the 44mm “D” crank). I don’t care to argue about the matter though, plenty of threads about that already.
I’m for now looking for a complete 504 bottom end or 504 crankshaft. Cheers.
Umm youre wrong. There is a longer stroked crank, but it was made for a 505. The 505 clutch side is the same, but the ignition side is different. The 504 has a smaller taper on a smaller flywheel with a 90mm stator plate. Its why in the other thread we were saying use a 505 d crank with a derbi flywheel, which has the same taper as a 505, and will fit inside the smaller 504 cases.
There are other threads for that debate, thank you. Here is one.
https://www.mopedarmy.com/forums/read.php?1,4257783
After Considering Daniels advice and the fact that no one seems to have a 504 crank, would anyone like to sell me a Derbi motoplat flywheel and/or 505/D crank?
Cheers.
I might have some 504 cases to mock it up in, maybe an extra derbi flywheel, but no crank. Treats has those though
