Looking for a Sachs 504 crank or perhaps a whole 504/505 bottom end! Whaddaya got!
Need shipped to 37216 (Nashville). Thanks.
Bump -
I need a 504 crank/flywheel/woodruff key
OR
A complete 504 bottom end.
No longer looking for 505 bottom end, which will not fit on a Sachs Westlake.
Thank you.
Sorry just had to leave this comment so I could follow the post. /bump!
Get a 505 d crank and a derbi motoplat flywheel. Time it with no key and enjoy 2mm of stroke on your wimpy 504.
To my knowledge, It has been debunked that there is a crank with a longer stroke (the 44mm “D” crank). I don’t care to argue about the matter though, plenty of threads about that already.
I’m for now looking for a complete 504 bottom end or 504 crankshaft. Cheers.
Umm youre wrong. There is a longer stroked crank, but it was made for a 505. The 505 clutch side is the same, but the ignition side is different. The 504 has a smaller taper on a smaller flywheel with a 90mm stator plate. Its why in the other thread we were saying use a 505 d crank with a derbi flywheel, which has the same taper as a 505, and will fit inside the smaller 504 cases.
There are other threads for that debate, thank you. Here is one.
After Considering Daniels advice and the fact that no one seems to have a 504 crank, would anyone like to sell me a Derbi motoplat flywheel and/or 505/D crank?
Cheers.
I might have some 504 cases to mock it up in, maybe an extra derbi flywheel, but no crank. Treats has those though
