Re: WTB: Running E50 engine
up shits creek /
> Trevor Fladwood Wrote:
> Super easy to rebuild! All you need is bearings and seals.. maybe 35
> bucks? A little more if you want to replace hardware and stuff.. then
> easy to match to a kit if you desire. If you need anything let me know,
> I’m in Hopkins, MN. Also, check the wiki for rebuilding an e50. It’s
> seriously a few hours of work, even for your first time.
thanks guy - in st cloud. my issue is I need a new crank because i gauled the small end bushing. so i need a crank,seals,piston to rebuild.
EDIT: I also lack most the specialty tools. so that's adding to my cost as well. see here https://www.mopedarmy.com/forums/read.php?6,4290096,4290503#msg-4290503 (edited)
