Re: WTB: Running E50 engine
> Nathan Kuebelbeck Wrote:
> > Trevor Fladwood Wrote:
> > Super easy to rebuild! All you need is bearings and seals.. maybe 35
> > bucks? A little more if you want to replace hardware and stuff..
> then
> > easy to match to a kit if you desire. If you need anything let me
> know,
> > I’m in Hopkins, MN. Also, check the wiki for rebuilding an e50. It’s
> > seriously a few hours of work, even for your first time.
> thanks guy - in st cloud. my issue is I need a new crank because i
> gauled the small end bushing. so i need a crank,seals,piston to
> rebuild.
> EDIT: I also lack most the specialty tools. so that's adding to my cost
> as well. see here
> https://www.mopedarmy.com/forums/read.php?6,4290096,4290503#msg-4290503
Was this on a kitted bike? And you don’t add tool the to cost because you will need them again.
