> Baron Von Hamilton Wrote:
> Right on man. That is the struggle. My solution to straight cut gears
> without dropping all the cash was turning 3 bearing reverse cut gears
> countershaft into a 4 bearing. I modified the shaft to a accept a
> bearing. Worked pretty well. Reverse cut gears put less stress on
> everything. Or at least I am told that, this is how the motors can run
> 3 bearing instead of 4.
> Let me know if you decide not to run it. I definitely want to try a KS
> one.
> Thanks!
Normal cut gears throw the bell and countershaft towards the clutch cover ( this puts a load on the circlip and can make it pop out) If you run a normal cut gear in 3 bearing case it will throw the counterahaft against the case wall and just heat up. Revere cut donโt put out less stress it just chages the direction of the stress and removes the weight load where itโs not wanted.
