Batavus crank stripped.
I bought a Batavus with no flywheel and the stator hanging off. I figured I’d throw on a Puch flywheel and be good to go. None such luck. It seems the threads are damaged on the crank. I can’t get a nut to grab the threads. Any suggestions? I can’t find a replacement crank at treats or anywhere else.
Re: Batavus crank stripped.
Re thread it the next size smaller.
Overpriced Parts /
That’s nothin Just chase the threads,
The cheepo Harbor freight metric tap kit should have the correct size one in it but looks like you have other problems too,
Take off the Stator and see if the crank is rusted where the engine case seal meets it
cut a nut or tap in half. start on the inside (clamp) and work out slowly with whatever u can hold it with.
Yea m10x1mm die will have you set straight. The pitting on that crank looks pretty bad though. You may want to lap the flywheel to the crank before running that.
♣Slew Foot♣ /
A rolling paper and red Loctite ancient Chinese secret
♣Slew Foot♣ /
But since this is in the buy and sell I would think that you're looking to buy one I got 3 shoot me an offer p.m.
