WTB: Tomos Iskra 4 coil/2 wire stator
Anybody have a working one they'd sell? Need one asap.
Like this:
Re: WTB: Tomos Iskra 4 coil/2 wire stator
♣Slew Foot♣ /
I have a few PM me...
♣Slew Foot♣ /
Oh nuts...
You can use a 4-wire for a kinetic or Luna or Indian 2 stroke Indian dot Indian not feather if you cross the Red White and the yellow that is your voltage out lightwise and then the brown is your ground to you the coil the other is the trigger the red
Bump!
What type of problems cause the stator to not work anymore?
♣Slew Foot♣ /
could be anything could be a coil fouled inside and Unwound and maybe a ground fault maybe a resistor boot or resistor plug that wasn't called for maybe both the moped gods piss on you could be one of a hundred things or maybe even two could be that the hall effect sensor just went bad or a stator side seal got oil on it your guess is as good as mine
