Re: C100 exhaust
Pushrod Fifty /
I lapped mine and it never leaked. Did you check the float for leakage, submerged in a glass of water? How about the gasket behind the needle seat and the plastic bowl seal?
My petcock was leaking as the seal had dried up. I brought a few replacements but they werent exact. The valve was cheesy and seemed too small in diameter to turn smoothly. I took the valve out of the body and plugged the hole with an aluminum disk and gas-resist gasket. Plugged one passage, Installed a motion pro inline fuel valve.
Look out for aftermarket carb kits, the gaskets can be cut undersized and cause the float to snag, improper jet sizes, inferior materials that aren't gas-resist.
  C100 exhaustTopic by: Tim Doll Tim Doll 01/15/20 11:18PM
  Re: C100 exhaustRe: Pushrod Fifty Pushrod Fifty 01/17/20 02:35PM
  Re: C100 exhaustRe: Tim Doll Tim Doll 01/17/20 07:34PM
  Re: C100 exhaustRe: Tim Veik Tim Veik 01/26/20 03:11AM
  Re: C100 exhaustRe: Pushrod Fifty Pushrod Fifty 01/17/20 07:58PM
  Re: C100 exhaustRe: Tim Doll Tim Doll 01/18/20 08:31AM
  Re: C100 exhaustRe: Pushrod Fifty Pushrod Fifty 01/18/20 09:59PM
  Re: C100 exhaustRe: Tim Doll Tim Doll 01/18/20 11:08PM
  Re: C100 exhaustRe: Aaron Blair Aaron Blair 01/18/20 11:34PM
  Re: C100 exhaustRe: Pushrod Fifty Pushrod Fifty 01/19/20 08:23AM
  Re: C100 exhaustRe: Tim Doll Tim Doll 01/19/20 08:53AM
  Re: C100 exhaustRe: Pushrod Fifty Pushrod Fifty 01/20/20 11:08AM
  Re: C100 exhaustRe: Tim Doll Tim Doll 01/20/20 03:56PM
  Re: C100 exhaustRe: Pushrod Fifty Pushrod Fifty 01/20/20 06:23PM
  Re: C100 exhaustRe: Tim Doll Tim Doll 01/20/20 10:20PM
  Re: C100 exhaustRe: Pushrod Fifty Pushrod Fifty 01/22/20 05:38AM
  Re: C100 exhaustRe: Tim Doll Tim Doll 01/22/20 07:24AM
  Re: C100 exhaustRe: Pushrod Fifty Pushrod Fifty 01/22/20 08:20AM
  Re: C100 exhaustRe: Tim Doll Tim Doll 01/22/20 10:21AM
  Re: C100 exhaustRe: Pushrod Fifty Pushrod Fifty 01/22/20 11:09AM
  Re: C100 exhaustRe: Tim Doll Tim Doll 01/22/20 12:26PM
  Re: C100 exhaustRe: Tim Doll Tim Doll 01/26/20 08:34AM
  Re: C100 exhaustRe: Pushrod Fifty Pushrod Fifty 01/27/20 08:29AM
  Re: C100 exhaustRe: Born to be WillD Born to be WillD 01/27/20 11:56AM
  Re: C100 exhaustRe: Pushrod Fifty Pushrod Fifty 01/28/20 08:49AM
