Honda C100 Carb
Looking for C100 50cc Carb and/or parts for a 1965 Honda Cub . Thanks
Re: Honda C100 Carb
You can buy a PZ20 china clone from ebay for about $12 shipped
Re: Honda C100 Carb
PM'd
Re: Honda C100 Carb
Pushrod Fifty /
Which part do you need? I have done spare parts. You can buy a direct replacemrnt on ebay for 45.00.
Re: Honda C100 Carb
I panicked a little and had bought the EBay carb for $40 , it needed a lot of filing to widen mounting holes , from 45mm to 38mm ; wasn’t sure it would work but after filing and adjusting throttle cable I started it up and it ran perfect. I also ordered a rebuilt kit for the original as I could never get it to idle right. I put out a shout out for parts but it runs fine now. Thanks
Re: Honda C100 Carb
Pushrod Fifty /
They look bigger than stock, is the throat the same diameter? Any performance improvement? Good thing is the one piece construction and float bowl drain screw.
Re: Honda C100 Carb
The throat is 20mm as opposed to 15mm on the original.I bought it because I couldn’t get consistency, idling ,leaking.surging. For only$40 shipped if nothing else It would would solve my curiosity. The mounting holes were 45mm and 38mm on the original, it took quite a bit of filing but no big deal.I put the new carb on and it started on the second kick ,idled smooth and never stalled ,something the original carb never did . It ran good through the whole throttle range. They sell a carb on EBay that’s I think made in Japan by the original manufacture,it also needs the mounting holes altered. It costs $80 and is probably better quality.I ordered a rebuild kit for the original carb for $25 shipped but will probably run with the China clone . Thanks
