FS: Misc Stock Hobbit Stuff
Stock crank, idr difference between PA50I and II. If you care, tell me and I'll check. Conrod bearing feels good - $30 shipped
Stock PA50I cylinder, super light surface rust should clean up fine. Gimme an extra 10 bux and Ill give it a fresh hone. - $30 shipped as is
Stock head, has some damage from a ring mishap. Decked just the tiniest bit just to clean it up. Effects on compression should be miniscule. I ran this for a long time no issues - $20 shipped
Stock pipes, 2 are pa50i, 1 is pa50ii. The II has some garbage header flange welds going on. I dont think these are worth the cost to ship and will probably end up scrapped. But if you really want one make me an offer and convince me to put it in a box.
Re: FS: Misc Stock Hobbit Stuff
Downhill Harvey (OFMC) /
pa50ii on the left
Thanks Harvey!
Mike:
Is one of the muffles for the PA50I still available.
Jack
> Jack Nielsen Wrote:
> Mike:
> Jack
Yes, PMed you
The PA50I pipe with the heat shield is sold
Up, make offers
