Quarantine Odds n Ends for sale!
🇮🇹💦 Of the Loin /
I've got various odds and ends for sale, as always + shipping (will try to be as cheap as possible, max is like 12 bux or whatever a flat rate box is)
1) Dellortos! all lever choke
a) Dellorto 14.9 has all pieces except slide: $5
b) Dellrto 12.12 Arbeo (no idle adjustment): $8
c) Dellorto 12.12. Arbeo (no idle): $8
2) Minarelli Angled head, some threads are stripped but some arent. Probably saveable: $10
3) Indigan 30mm Red Clip on bars: I have never found my body to work with clipon bars: $20
4) EBR Puch Magnum Triple Tree only: $15
5) Polini brand 15mm intake for Polini kit or other reed kit with same pattern, $15
6) Minarelli V1 80cc polini kit, bore is nice and clean and taken off a running bike. Cylinder is definitely broken in and has plenty of power (I never modified it). Oneo f the cylinder fins is broken, and doesnt come with a piston or rings or anything: $50
No siezing and no smudges on bore.
if you're local to SF ill socially distantly drop it off for you
