WTB Vespa Grande Steering Column Key latch Cover.
ELLAK MOLNAR /
I'm looking for the Flat swinging Lock "COVER" that covers the little steering column lock located on the front right side of the steering tree. I already have the replacement Lock, key and spring assembly. I'm just looking for the Flat Silver cover that goes over the keyhole and swings to the side to access the lock and insert the key. Also if possible, I would also like the old Factory Rivet that holds the lock cover in place. Rivet can be re-used again if taken out with care. Unfortunately, the Grande I'm currently restoring did not come with a lock or lock cover.
