FS: built hobbit stage 6 motor + mlm subframe
campeona del mundo /
you wanna go fast? if that's a yes, then you've probably been eyeing this bad boy up for a while. this is actually one of the first 2 stage 6 builds that was involved in the prototyping of the hobbit adapter plates at treats. it's got stock cases bored to accept the stage 5 lc kit skirt, a DOS cycles 12p crank, viton crank seals, oko DIO intake and reed block adapter and to finish it off, a well used hpi internal rotor (cdi box and coil are not shown).
the squish has been set to 0.8mm (iirc) and everything is pretty much ready to go. it has never been fired up before!!
the cylinder head is missing one of the blockoff plugs for a water temp sensor. you'll want to run a temp gauge anyway, right?
crank $90
kit $560
subframe $200
ignition $250
intake $30
reed adapter $48
a grand total of $1178 WOWZA that doesn't even include the cases, gaskets, bearings n seals!!
you can have IT ALL for $780 shipped. (edited)
Re: FS: built hobbit stage 6 motor + mlm subframe
bump
Dirty30 Dillon /
Hobbit people sleeping on this deal are str8 dummies.
Never wanted a Honda more....
Is mine now.
sold
ughhhh screaming deal was missed :(
