Working on this 210 sport for a customer. Looking for some missing clutch parts and the pedal engagement assembly. Would consider a whole motor if available. Shipping to Little Falls Ny 13365. Let me know if you have anything. Thanks!
Correct me if I'm wrong but the X25 is a 207 engine [207.385] and doesn't share any clutch parts with the 210.
Yeah your right I’m losing my marbles. Lol. Have way to many mopeds. Lol
Well worst case an engine swap would be very easy to do so it's a worthwhile option if things are borked and heck swap the cylinder over and toss a 13 tooth on it and it's a cruiser. Electrical would be a problem though, but nothing that can't be sorted...either way it's a good option to have out there. (edited)
Thanks for the offer. I'm going to hold out for the 2 speed parts. I have had a couple 1 speed jawas and would like to see how the 2 speed is.
I even have new tires for it.
Bump
Unrelated but if you do source up a new engine for the customer and end up with that old one let me know, I'm in need of a 210 cylinder.
I bought a 207 just like brians non running for about 100.00
I wouldn't spend more than 200.00 on a non running moped.
Mine needed a new thyristor, petcock, plugs, and gas tank cleaned. Yours would probably need that too. Remember the decompression lever is to turn off the motor so you don't need to pull it while your starting it.
I also bought a 210 motor (single speed) to swap onto my 207 but from the blogs it might not match up correctly. Electrical stuff should work fine but I believe the motor mounts wont match up. I didn't try yet.
210 motor is 2 speed. This one was running but wouldn't move due to the missing transmission parts. Still looking for parts or a complete 210 motor.
Now I see why the seller didn't respond to me. I was going to grab that for the motor. Should be a 2 speed.
Bump
Bump
Bump
Not sure if this will help but,
Jawashop.com is probably going to be your best bet for parts. But expect to wait alteast a month since there in the czech Republic. But they do ship to the us!
