Wanted: Puch E50 Coils
Anyone have ignition coils that are no longer needed? I just pick up a 1977 Puch maxi single speed E50 and was told that it has been in a shed for 10 years. It must not have been, when I pulled the cover the flywheel is all rusted up and the coils are all rusty. I need a bunch of other parts too so if you have ignition parts to spare. Please let me know. Thank you
Re: Wanted: Puch E50 Coils
Tweaker trash /
Ul probably want everything including the flywheel! Post pics!
How does the crank look!?
The crank I am trying to save. I have sanded it some and put new bearings on it. Yes the entire motor is not the best condition. I got stuck on this deal I feel, paid too much. I hope to clean out the tank and carb good enough. Will post up pics tomorrow.
up shits creek /
handle bars look a bit bent back?
This is what the coils look like now after I tried to clean them and put new points on.
Change that condenser man
Overpriced Parts /
If 1977 it’s a 5 wire system so post for complete a 5 wire Stator because that one is shot pretty much
Yes. If anyone has a 5 wire stator that works to spare that would be great. I would pay for shipping.
You should probably get the whole flywheel and everything while you're at it, I bet the flywheel is shot too.
Overpriced Parts /
The point cam on flywheel needs to be rust free no pits, smooth and well lubed (or it will wear out the points follower) like this one |
You need to make a new thread in buy+sell like this
(“Wanted to buy Puch flywheel and five wire Stator”) it looks like from the wiring diagram you could make a six wire stator work though you would need to change the wiring a little bit
