Re: Wanted: Puch E50 Coils
Overpriced Parts /
> Graham Motzing Wrote:
> You should probably get the whole flywheel and everything while you're
> at it, I bet the flywheel is shot too.
The point cam on flywheel needs to be rust free no pits, smooth and well lubed (or it will wear out the points follower) like this one |
You need to make a new thread in buy+sell like this
(“Wanted to buy Puch flywheel and five wire Stator”) it looks like from the wiring diagram you could make a six wire stator work though you would need to change the wiring a little bit
