NU50 Throttle Pipe
Anyone have a spare or know where I can buy a throttle pipe? See #10 in diagram.
Or any ideas of a replacement that would work?
Thanks in advance,
Joe
Re: NU50 Throttle Pipe
have you looked around on treatland ?
They have a good OEM and aftermarket part selection, bikebandit.com also has some OEM stuff still available.
Thanks for that - looks like MAYBE on treatland. They have 2 different throttle tubes, but say they are for PA50II, PA50I, NA50, NC50. So not sure if that'll work for an NU50 as I don't know the size of the bars on any of these bikes.
Joe
I had to get one on Ebay and it was nos for $20.00 or so.
Re: NU50 Throttle Tube
Thanks. Will keep watching.
Do you havean old one we can use to compare? I might have what you need
Yes, I have the old one. I'll take measurements and pics tomorrow.
Thanks,
Joe
It might be sunday before i will be back where mine is..if you can post a few pics it might make it easier to know which one it is
Will do sir.
The overall length is 5" or 12.5 cm. Outside diameter is 1" or 2.5 cm, inside diameter is 7/8" or 2.2cm.
I've sent measurements and pics to treatland as well to see if their advertised tubes are the same.
Thanks again for your help.
Joe
