WTB: Minarelli V1 KickStart Gear / Assembly
🇮🇹💦 Of the Loin /
Not sure what this officially is called, but mine uhh was I guess tackwelded together and has just fallen apart.
its the gear that the return spring binds to
willing to buy the kickstart assembly too I guess if you dont wanna take it apart
Re: WTB: Minarelli V1 KickStart Gear / Assembly
I have a parts motor, I can take a look at it.
Mine is different?
🇮🇹💦 Of the Loin /
hahaha of course mine is some wierd variant of millions of minarelli parts
I think this one is a fantic, it has a very long kickstart arm (it extends out away from the bike like, 4-6 inches) which I need for the bike its on, so I don't think I can use that unless the shaft slides out somehow
I do have the 4 bolt retaining plate so at least that is the same (Carabela uses a 3 bolt retaining plate)
I appreciate you looking
Three bolt and 4 bolt retaining plates are interchangeable I ended up having to do that on one of my bikes.
The shaft does look like it could be pressed out, I would need to look at it closer. Let me know if you end up wanting to try that out.
I got some extra kick part shit. Have you talked to dos or I have another contact. I would separate with stuff if you need it asap. You were trying to sell a kick gear awhile ago and never got back to me?
Sent you a pm
🇮🇹💦 Of the Loin /
I checked I didn't see a PM from you in the last year but idk totally possible
I'll ask Dos and bump the thread
Not sure if you found one already but if not you can have this one.
