1977 Puch Maxi with a rebuilt and resealed motor and clutch assembly. Custom paint job, check the pictures, that is real 24k gold son! tons of aftermarket parts. runs great.
parts:
1) rebuilt motor, all new bearings, seals, stuffed crank.
2) treats reed kit. ported, polished and relieved.
3) Malossi 4 petal reed block.
4) Mikuni VM21
5) CDI ignition
6) MLM VM21 intake
7) Larger head studs
8) EBR hydraulic front forks
9) Magura hydraulic front disc brake.
10) Puch long seat
11) MLM Super reinforced rear swing arm.
12) Vespa 17" mag wheels
13) Hutchinson racing tires
14) Treats side bleed pipe.
15) Adjustable rear shocks
16) EBR frame brace
17) motion pro twist throttle.
I am sure there are other things on the bike that I have forgotten. all that is left for you to do is wire up the lights and turn signals. It will come with a big box of spare parts, different chain sprockets, different heads, gaskets, seals, odds and ends. Asking $1500 or best offer. located in san luis obispo, Ca. (edited)
