Need E50 Case Snap Rings
I have like 2 or 3 sets of cases I was going to build but I realize they're all missing the snap ring that goes between the seal and bearing on the counter shaft. Anyone have a line on these? Treats is out:
https://www.treatland.tv/the-NR-snap-ring-for-puch-E50-cases-p/nr-ring.htm
Re: Need E50 Case Snap Rings
You can just use the old snap ring off of the 6203nr bearing you’re about to throw in the trash.
Good to know, don't know why I didn't check that. These cases don't have old bearings so I'll scrounge some up, thanks!
Worst case just buy nr bearings and take the ring off them, and use the ring-less bearing in the regular location.
Locally I can get nr bearings cheaper than normal 6203. The bummer is they’re axis brand.
