> Taylor King Wrote:
> > Jay Rivett Wrote:
> > Free spirit is to magnum as pinto/swinger is to cobra
> > If parts swap over from free spirit to pinto I would be surprised.
> The
> > whole frame is a different size. Some things would be the same size,
> > like a fender, but mounting holes would probably not match up. Seems
> > like an easy problem to fix tho. I agree with Mike that the maxi-n
> > would be close to the same size as the pinto, but parts wont swap over
> > easily either.
> What part of the frame is different? I own both and haven't noticed
> anything different. I've put a spare pinto tank on my freespirit to get
> it running while the Free Spirit tank was soaking in cleaning solution.
The tanks use a U clamp to hold onto the tube style frame they both have. But the length of the frames are completely different. I have owned both bikes as well and a magnum, and have compared things with my friends cobra.
Plastic lower side covers wouldnt work between the two bikes. Forks, shocks, and swing arms are all different lengths between the two bikes. So yeah lots are different and would not be interchangeable unless you are trying to make a mini free spirit, or a large pinto....
