WTB: Batavus ignition coil
No spark in need of ignition coil for m56!
Re: WTB: Batavus ignition coil
♣Slew Foot♣ /
Internal or external if you mean the ht external I have any would work.
Tri-ped Dave O.D.B. /
HT Coil is least likely culprit. Test yours. Across the positive to ground should be 1.5 ohms. Way more likely condenser or points.
Internal
This is the coil that Robert Parr is referring to. Previous owner soldered the winding of the ignition coil. This one is measuring ~2ohms (assuming it needs to be less thane 1ohm).
- Points have been cleaned and adjusted
- Spark plug cable and boot have been replaced
- Blue/black wire grounded (http://www.myronsmopeds.com/wp-content/uploads/2008/08/Batavus-Regency-Wiring1.jpg)
- Condenser replaced
- Disconnected the kill switch
- Swapped out H.T. coil with known good one
...still no spark. (edited)
♣Slew Foot♣ /
Did you by chance replace the oem horn? Did you check motor to frame ground?
So,....does anyone have an extra “internal” ignition coil I could buy
Someone gotta have a Bosch ignition coil. They are not Bat specific
Eric Davenport /
I may have one. I'll have to check
♣Slew Foot♣ /
The reason I ask is the bat has an oem specific horn and if it was replaced with a puch Tomos Sachs horn you'll get nodda on the Iggy.
So, I rewound the primary ignition coil and Voila--Spark!!!
