Re: V1 Marinelli Trouble Shooting
Mark Ryan /
could be a rusty gas tank mixed with dirty carb or an air leak. The bogging shows signs of dirty carb or air leak while the dying engine seems like crap is getting in your carb- I.E. dirty/ rusty gas tank-
1st. Clean the carb very well --then reinstall and while it is idling spray carb cleaner at various points around the carb and intake- if it kills the engine you have an air leak. If so, use RTV gasket red sealer from Napa or auto zone and seal up where it leaks.
Also, for the tank I would install in inline fuel filter from auto zone- costs 2.50. it is easy as pie to install and will prevent most light rust/dirt from your tank from clogging your main jet in the carb.
If it still bogs you most likely are running a too large main jet (brass screw in carb) and you need to down jet. its a dellort 14.12 on a V1 right? good news is 1977mopeds has all ranges of dellorto jets for you. Though my bet is on 1 and 2.
Good luck- i dont think it is the condenser personally. nor a soft sieze. 1 and 2 are the most common issues.
  V1 Marinelli Trouble ShootingTopic by: Serious Business Serious Business 08/07/07 01:25AM
  Re: V1 Marinelli Trouble ShootingRe: andrewhd andrewhd 08/07/07 01:42AM
  Re: V1 Marinelli Trouble ShootingRe: Bitter Bitter 08/07/07 01:46AM
  Re: V1 Marinelli Trouble ShootingRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 08/07/07 10:07AM
  Re: V1 Marinelli Trouble ShootingRe: Serious Business Serious Business 08/07/07 01:58PM
  Re: V1 Marinelli Trouble ShootingRe: Mark Ryan Mark Ryan 08/07/07 03:44AM
  Re: V1 Marinelli Trouble ShootingRe: Michael Michael 08/07/07 05:37AM
  Re: V1 Marinelli Trouble ShootingRe: Serious Business Serious Business 08/07/07 01:55PM
  Re: V1 Marinelli Trouble ShootingRe: mopedmaniac mopedmaniac 08/07/07 11:34AM
  Re: V1 Marinelli Trouble ShootingRe: Serious Business Serious Business 08/07/07 01:52PM
  Re: V1 Marinelli Trouble ShootingRe: Mark Ryan Mark Ryan 08/07/07 04:23PM
  Re: V1 Marinelli Trouble ShootingRe: Silverfox Sullivan Silverfox Sullivan 08/07/07 10:36PM
  Re: V1 Marinelli Trouble ShootingRe: Silverfox Sullivan Silverfox Sullivan 08/07/07 10:37PM
  Re: V1 Marinelli Trouble ShootingRe: Mark Ryan Mark Ryan 08/07/07 11:22PM
  Re: V1 Marinelli Trouble ShootingRe: Serious Business Serious Business 08/08/07 12:45AM
  Re: V1 Marinelli Trouble ShootingRe: Serious Business Serious Business 08/08/07 01:32AM
  Re: V1 Marinelli Trouble ShootingRe: Mark Ryan Mark Ryan 08/08/07 02:42AM
  Re: V1 Marinelli Trouble ShootingRe: Isabelle Castillo Isabelle Castillo 01/25/19 06:32PM
  Re: V1 Marinelli Trouble ShootingRe: P D P D 01/25/19 06:47PM
  Re: V1 Marinelli Trouble ShootingRe: Don Ohio Don Ohio 01/25/19 08:38PM
