Re: V1 Marinelli Trouble Shooting
Michael /
Never have delt with a Minarelli, but here are the following things to do with any used moped:
1. Clean the carb. Take it apart and wash/swirl it in gas. Then dry everything off and put back together.
2. Remove all carbon. Most peds get carbon on the head and piston. If black/dark brown, use steel wool and remove it until you can see the original color.
3. Change the Plug. Use an Autolite 425, NGK B6HS, ND W20FS-U, Bosch W9EO or Champion L86C. Put the gap at I believe .26 - .28mm
4. Change the fuel line and petcock. Use 3/16" Nitrile or Tygon fuel line, it will last the longest. Also use a fuel filter or two. Also, replace the petcock, sometimes the filter on it corrodes and lets rust build up. Save time and buy one.
Try tightening the nuts on the engine studs. After that, if it still doesn't run properly, adjust the carburetor and check the electrical like Mark said.
Good Luck
  V1 Marinelli Trouble ShootingTopic by: Serious Business Serious Business 08/07/07 01:25AM
  Re: V1 Marinelli Trouble ShootingRe: andrewhd andrewhd 08/07/07 01:42AM
  Re: V1 Marinelli Trouble ShootingRe: Bitter Bitter 08/07/07 01:46AM
  Re: V1 Marinelli Trouble ShootingRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 08/07/07 10:07AM
  Re: V1 Marinelli Trouble ShootingRe: Serious Business Serious Business 08/07/07 01:58PM
  Re: V1 Marinelli Trouble ShootingRe: Mark Ryan Mark Ryan 08/07/07 03:44AM
  Re: V1 Marinelli Trouble ShootingRe: Michael Michael 08/07/07 05:37AM
  Re: V1 Marinelli Trouble ShootingRe: Serious Business Serious Business 08/07/07 01:55PM
  Re: V1 Marinelli Trouble ShootingRe: mopedmaniac mopedmaniac 08/07/07 11:34AM
  Re: V1 Marinelli Trouble ShootingRe: Serious Business Serious Business 08/07/07 01:52PM
  Re: V1 Marinelli Trouble ShootingRe: Mark Ryan Mark Ryan 08/07/07 04:23PM
  Re: V1 Marinelli Trouble ShootingRe: Silverfox Sullivan Silverfox Sullivan 08/07/07 10:36PM
  Re: V1 Marinelli Trouble ShootingRe: Silverfox Sullivan Silverfox Sullivan 08/07/07 10:37PM
  Re: V1 Marinelli Trouble ShootingRe: Mark Ryan Mark Ryan 08/07/07 11:22PM
  Re: V1 Marinelli Trouble ShootingRe: Serious Business Serious Business 08/08/07 12:45AM
  Re: V1 Marinelli Trouble ShootingRe: Serious Business Serious Business 08/08/07 01:32AM
  Re: V1 Marinelli Trouble ShootingRe: Mark Ryan Mark Ryan 08/08/07 02:42AM
  Re: V1 Marinelli Trouble ShootingRe: Isabelle Castillo Isabelle Castillo 01/25/19 06:32PM
  Re: V1 Marinelli Trouble ShootingRe: P D P D 01/25/19 06:47PM
  Re: V1 Marinelli Trouble ShootingRe: Don Ohio Don Ohio 01/25/19 08:38PM
Want to reply to this thread?
