Quote: "Remove all carbon. Most peds get carbon on the head and piston. If black/dark brown, use steel wool and remove it until you can see the original color."
If the carb clean up / possible replacement does not solve the issue... this step will be in order.
What might the torque spec be for putting the head back on ?
