Motobecane Magneto cover - CAN'T REMOVE IT!
Working on my '78 Moby 7, and trying to get the cover off the flywheel to replace my condenser, but can't find the tool I need to remove it. Anyone have a source for the square drive wrench 100023? Anyone have a suggestion for a standard tool that will do the job, or a dimension for the "square drive" itself (looks like about 20mm or so)?
Re: Motobecane Magneto cover - CAN'T REMOVE IT!
I use a 3/8" socket driver and strike it with a hammer shile holding the flywheel with a strap wrench. Remember it's left handed threads so it's Righty loosey and lefty Tighty.
Rusty
remember the nut is reverse threaded (CW to loosen). I used a piston stop to immobilize the magneto and a 3/8" socket with handlebars slid over the handle for a lever to break it free the first time. after that you can just get it off with the socket. impact drills are a bad idea according to me. map gas and PB blaster are also a bad idea according to me.
***Kim Jong illest*** /
^^^i second that. just use your ratchet and stomp on it. bam. done. also, use a piston stop.
make sure you're not leaning over your bars when you try to break that nut free, I almost took at my eye and may or may not have lost consciousness for a second.
HAHA
Thanks- I knew there was an easier way to do this!
I personally had to hack off the sides of the nut so that it was rectangular which allowed me to use a wrench to turn it.
Good way to get it off, but a bit destructive. Would have to buy a new one most likely afterward.
I am struggling with this right now, and I think I am going to have to cut it out. Where can a i buy a new nut, and perhaps cover?
https://www.treatland.tv/SearchResults.asp?Search=novi+nut
if you cut the edge a little with an angle grinder you might be able to knock it free with a chisel in the correct direction,
Pushrod Fifty /
It takes a 10mm square drive.
That^ is a hair more than 3/8" . So , any 3/8" ratchet or breaker bar should fit with a very slight amount of play . Just right . ;)
For what it's worth, the Peugeot 9759 wrench is the closest tool I could find. It's a double ended 10/8 mm square drive. Mostly fits the 11 mm reverse threaded Novi nut. Also useful for Volvo cars.
Richard Eberline /
Its a 10mm square drive socket and a 3/8" drive Rachet is to small. Pushrod told you in this post. So it is a 10mmmmmmmmmmmmmmmm
Now that I have a proper square socket, they seem to come off a bit easier, but here's what I've done numerous times. use a 32mm bicycle headset wrench, center it on the dome of the flywheel nut, take a sharpie and trace the inside of the wrench. Next use a cutoff tool/die grinder and cut the dome of the nut to fit the cone wrench, blast it with penetrating oil, give it a little heat, and it will usually come loose, I've done some REALLY stuck ones this way.
3/8 inch socket driver in an electric impact is the only thing I use. Haven’t ruined one yet!
I tried with my Craftsman impact and didn't work. I had to fill the cylinder with rope and then use a ratchet with a long ass pipe on it to bust mine off. I've done it with 3 AV7s now with ease
