Re: Choke Trouble on Dellorto SHA 15
Shut off fuel.
Have rag or towel under carb to catch leaking gas.
Two screws on bottom of carb release the bowl. Inside you will find all kinds of junk including round brass main jet.
Be careful not to bend float or loose the float pin. Pin must be centered upon re assembly or bowl will not fit back on.(edited)
Duh- you meant the screw. I think. lol Yes i cleaned that out. But it was really ok anyway.
When cleaning the carb you should physically handle every part in this exploded parts diagram .
For a detailed picture of parts with corresponding #s :
https://www.dellortoshop.com/contents/en-us/d71_Dellorto_SHA14_SHA15_and_SHA16_Parts.html
Thanks. I guess it will have come off the bike. Might wait til i find someone with more experience putting it back on the throttle to help.
Roy kindly go start your own thread you jack-ass.
This is Nicks thread and you are hi-jacking it.
Im sorry- it seemed like nick had already received his solution and i didn't want to start another similar thread. People are so touchy these days... not going to bother
