Re: How do I Remove the Pulley on a 80 Motobecane?
Ian T /
1. remove pedal crank
2. remove dust cover, it is pressed on, I usually use pliers to twist it off, gently so as not to mar it, often i will put something soft in between the pliers and the dust cover.
3. remove circlip
4. remove pulley
or just read the manual :)
