Re: How do I Remove the Pulley on a 80 Motobecane?
Adam Margovic /
It's worth a shot! I will try it- There's probably a "sweet spot" when bending them that's enough to grab but not too much that they won't pass into the clip holes. Thanks!
Giovanni Lema Wrote:
> I had a similar issue the firat time i tried. I
> had to slightly bend the tips of my clip plyers.
> ie if they open pitch out if they close pitch in.
> I just used my small bench vice and carefully
> pushed or pulled!! Hope that helps
