Tomos Silver Bullet TS 1981 Battery / Electrical
I just picked up my first moped a couple weeks ago and have been blissfully tinkering around with it while waiting for some money to free up for a helmet and registration so I can drive it to and from work (6 miles both ways). The bike is a 1981 Tomos Silver Bullet (TS, I guess because it has stock turn signals). Runs really good right out of the gate and only has 1700 miles on it, seems pretty low for its age. So far I have cleaned it up, started polishing, fixed a leaky 2 stroke oil hose, tightened some loose nuts/bolts and now I am trying to get the electrical system up to 100%.
Right now the headlights, breaklights, horn and oddly enough the left front turn signal only are functioning, but all are dimming and brightening with the rmps of the engine. The one working turn signal will only come on when the engine is really cranking, doesn't work at idle at all. Upon inspection I found one green wire under the rear fender that was damaged and exposed, but not totally disconnected. Also inside the control switch for the turn signals and engine run/off, there was a piece of solder that had come loose resting between two of the turns signal control prongs. Took that out and cleaned all connects with DeoxIT cleaner (highly recommended for all vintage electronic cleaning). Also, checked all the non-functioning turn signal bulbs and wires and they all seem to be good. Which brings us to the main topic...
The infamous and evasive Tomos BLACK BOX that houses the electrical components. I've read a few threads on here about the black box and its contents, but mostly it seems to be somewhat unknown territory, so I thought Id share my experience and post some picks to help shed some light.
Firstly, the box from my 1981 most definitely contains a 6v battery pack made of 5 1.2v cells connected in a 3x2 stack, just like a standard 6v RC battery you can buy at a hobby store or online for a radio controlled car, plane, ect. I yanked that battery out and it is TOTALLY dead, no charge at all (it is like 30 years old). So, I am going to order another 6v pack from ebay for like $12 and install that. One really weird thing is this little, round black plastic piece that was connected to the bottom of the battery, in the middle of the chain of cells, on a negative terminal. It has two yellow wires connecting the other end to the circuit board. After Googleing the part numbers on it, I found a site that talked about the part also being used in washer and driers as an electrical thermostat. So, Ive come to the conclusion that its function is to break the connection between the battery and the stator (charger in this case) if the battery gets too hot.
If all goes as planned I'm thinking that the turn signals and hopefully all the lights will work with the new battery independently from the rpms of the engine and the engine will charge the battery.
I'll post pics of the box, battery and thermostat if anyone is interested. Sorry if Im rehashing old stuff here, but I scoured this site and couldn't find anything this specific on the topic.
Re: Tomos Silver Bullet TS 1981 Battery / Electric
♣Slew Foot♣ /
well to chime in
i dont think the batteries recharged from the bike
rather it acted as the flasher and turn signals power source
as re chargeables were 90s tech
i have seen these boxes on puchs
mainly because the coils on the flywheel cant generate enough juice
to run the whole shebang hence the winking at low rpm
even some of the newwer tomos's need higher idle to flash the signals
specially when at a stoplight never seen a tomos with the box tho
good luck
The battery that came out of the black box looks ancient and the label says:
SUPERPILA (brand name)
Batteria Nichel Cadmio
Ricaricabile 6V 5xSCX
Cat No SB880
I believe that is Italian for 6 volt nickel-cadmium rechargable battery. All the different sized conectors (pos, neg and the themostat) on the battery fit the circut board of the Tomos so I think it is stock.
My camera is charging right now so Ill post pics later. Im still holding on to the theory that a fresh battery will allow me to run all the electric with constant juice even while the engine is off and the battery will recharge while Im riding. Hopefully not just wishful thinking!
This setup must have only been on a few models from that period. Hopefully this thread will be usfull for people who want to try to build a simple rechargable system, I know quite a few peeps have asked about it on here. Just imagine... turn signals at a stop sign! What a concept.
Actually I think the singnals a little goofy, but I dont want to take them off since they are original. Ill use em on the road for sure though if I can get em going.
Danny Krotzer /
Almost 5 years later...
Did it work out for you with the reconstruction? I'm going to attempt the same. Thanks for posting your notes...
Luke Micallef /
And over another 5 years later.
Attempting the same. Any advice?
You might try an electronic relay instead of a 'juice' sucking electro-mechanical .
