Re: 1980 Honda Express NC50 wiring questions
Adam Kollipara /
Yeah the original wiring diagram isn't very clear. I know that Mel posted a thread about adding turn signals on a 78, and had a color wiring diagram. Pretty sure the colors are the same because Mel used a 1980 wiring harness. It's possible that your wiring harness is damaged somewhere, maybe, maybe not.
As for the air filter, if you want a new stock one, look on eBay or cut one out of a sponge and soak in motor oil. If you want an aftermarket one (seems like you do) you can get some small air filter from treats. I think the carb intake diameter is 24mm, about an inch.
~Adam
  1980 Honda Express NC50 wiring questionsTopic by: Landry T. Landry T. 08/08/11 08:56PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Adam Kollipara Adam Kollipara 08/08/11 10:09PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Landry T. Landry T. 08/08/11 10:59PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Adam Kollipara Adam Kollipara 08/08/11 11:29PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Landry T. Landry T. 08/09/11 12:15AM
  Re: 1980 Honda Express NC50 wiring questionsRe: K L K L 08/09/11 01:49AM
  Re: 1980 Honda Express NC50 wiring questionsRe: Adam Kollipara Adam Kollipara 08/09/11 03:45PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Josh Cranston Josh Cranston 08/09/11 02:00AM
  Re: 1980 Honda Express NC50 wiring questionsRe: Green Marauder Green Marauder 08/09/11 07:46AM
  Re: 1980 Honda Express NC50 wiring questionsRe: K L K L 08/09/11 08:29AM
  Re: 1980 Honda Express NC50 wiring questionsRe: Landry T. Landry T. 08/09/11 02:36PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Green Marauder Green Marauder 08/09/11 02:50PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Landry T. Landry T. 08/09/11 03:24PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Adam Kollipara Adam Kollipara 08/09/11 04:17PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Green Marauder Green Marauder 08/09/11 04:22PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Landry T. Landry T. 08/09/11 06:04PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Green Marauder Green Marauder 08/09/11 07:37PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Adam Kollipara Adam Kollipara 08/10/11 01:59PM
  Re: 1980 Honda Express NC50 wiring questionsRe: billy baroo billy baroo 05/11/15 03:47PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Jack Rutherford Jack Rutherford 08/03/20 11:47PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Eric Wehrs Eric Wehrs 07/26/12 12:24AM
  Great InformationRe: Merle Schlotfeld Merle Schlotfeld 08/02/20 02:24PM
