Re: 1980 Honda Express NC50 wiring questions
Adam Kollipara /
I think what Mel is talking about is a little black button type thing behind the brake lever. If you pull the left/right brake levers back, and look behind it near the brake cable, you'll see a little black plastic button. When the brake lever is not pulled, the button is pressed in, not allowing the brake light of the taillight to illuminate. When the brake lever is pulled, the button is not pressed in, causing the brake light of the taillight to illuminate. I attached some pictures of the button: a close up, one from underneath, and one from the side farther away. Maybe yours is stuck in, not allowing it to get bright when pulling the lever. Check this on both levers.
~Adam
  1980 Honda Express NC50 wiring questionsTopic by: Landry T. Landry T. 08/08/11 08:56PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Adam Kollipara Adam Kollipara 08/08/11 10:09PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Landry T. Landry T. 08/08/11 10:59PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Adam Kollipara Adam Kollipara 08/08/11 11:29PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Landry T. Landry T. 08/09/11 12:15AM
  Re: 1980 Honda Express NC50 wiring questionsRe: K L K L 08/09/11 01:49AM
  Re: 1980 Honda Express NC50 wiring questionsRe: Adam Kollipara Adam Kollipara 08/09/11 03:45PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Josh Cranston Josh Cranston 08/09/11 02:00AM
  Re: 1980 Honda Express NC50 wiring questionsRe: Green Marauder Green Marauder 08/09/11 07:46AM
  Re: 1980 Honda Express NC50 wiring questionsRe: K L K L 08/09/11 08:29AM
  Re: 1980 Honda Express NC50 wiring questionsRe: Landry T. Landry T. 08/09/11 02:36PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Green Marauder Green Marauder 08/09/11 02:50PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Landry T. Landry T. 08/09/11 03:24PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Adam Kollipara Adam Kollipara 08/09/11 04:17PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Green Marauder Green Marauder 08/09/11 04:22PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Landry T. Landry T. 08/09/11 06:04PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Green Marauder Green Marauder 08/09/11 07:37PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Adam Kollipara Adam Kollipara 08/10/11 01:59PM
  Re: 1980 Honda Express NC50 wiring questionsRe: billy baroo billy baroo 05/11/15 03:47PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Jack Rutherford Jack Rutherford 08/03/20 11:47PM
  Re: 1980 Honda Express NC50 wiring questionsRe: Eric Wehrs Eric Wehrs 07/26/12 12:24AM
  Great InformationRe: Merle Schlotfeld Merle Schlotfeld 08/02/20 02:24PM
