Brown supplies power to the tail light. Green is ground. Orange and lite blue are the left and right turn signals (tells them to blink) and run from the turn signal switch on the handlebars to the turn signals. And, like I said, green and yellow wire is for the brake light. You should be able to track this down. Make sure all your connections are clean and tight.
Re: 1980 Honda Express NC50 wiring questions
