Re: Honda Express Cylinder Jug Removal
*.* HONDA /
Hey Adam,
I had troubles getting a cylinder off of my honda. My mechanic friend had me tap it with a hammer on the side with the fins with some wood and after so many POOF the cylinder slid straight off and over the piston. On another case I had laying around I had trouble getting the piston through the cylinder, hopefully you don't have trouble with that.
As for shops, I have not used either but according to this - you can use any honda 50cc rings ["Hobbit, NC50, NA50, NU50, NX50, etc."]
$10 + Shipping honda hobbit stock chromed piston rings set - 40mm x 1.5mm
The other moped shop 1977 Mopeds does not have any stock rings for some reason but a good shop to know about nonetheless
Hopefully that helps. You should order up a set of new gaskets -- Base and head -- too I guess since they are reasonably priced.
Be sure to make sure the cylinder looks clean also. Otherwise you may want to order a Piston + Rings $30 - If it is scored get the 44mm and get it bored haha
How many edits can I do! (edited)
  Honda Express Cylinder Jug RemovalTopic by: Adam Kollipara Adam Kollipara 08/08/11 11:46PM
  Re: Honda Express Cylinder Jug RemovalRe: *.* HONDA *.* HONDA 08/09/11 05:33AM
  Re: Honda Express Cylinder Jug RemovalRe: Green Marauder Green Marauder 08/09/11 07:36AM
  Re: Honda Express Cylinder Jug RemovalRe: Green Marauder Green Marauder 08/09/11 08:25AM
  Re: Honda Express Cylinder Jug RemovalRe: K L K L 08/09/11 08:38AM
  Re: Honda Express Cylinder Jug RemovalRe: *.* HONDA *.* HONDA 08/09/11 01:00PM
  Re: Honda Express Cylinder Jug RemovalRe: *.* HONDA *.* HONDA 08/10/11 08:08PM
  Re: Honda Express Cylinder Jug RemovalRe: Adam Kollipara Adam Kollipara 08/09/11 03:20PM
  Re: Honda Express Cylinder Jug RemovalRe: Tim McGarvey Tim McGarvey 08/09/11 03:30PM
  Re: Honda Express Top End AssemblyRe: Adam Kollipara Adam Kollipara 08/30/11 10:04PM
  Re: Honda Express Top End AssemblyRe: Noah Reinhart Noah Reinhart 08/30/11 11:20PM
  Re: Honda Express Cylinder Jug RemovalRe: *.* HONDA *.* HONDA 08/31/11 02:56AM
  Re: Honda Express Cylinder Jug RemovalRe: Adam Kollipara Adam Kollipara 08/31/11 07:13PM
  Re: Honda Express Cylinder Jug RemovalRe: Glenn Kuehn Glenn Kuehn 09/05/11 02:27PM
  Re: Honda Express Cylinder Jug RemovalRe: Green Marauder Green Marauder 09/05/11 04:30PM
  Re: Honda Express Cylinder Jug RemovalRe: Abby King Abby King 03/01/19 03:16PM
  Re: Honda Express Cylinder Jug RemovalRe: Adam Kollipara Adam Kollipara 11/12/11 12:38PM
