Re: Honda Express Cylinder Jug Removal
*.* HONDA /
^haha yeah, dishwasher.
You could easily re-use the stock metal head gasket if you clean it up well with carb cleaner and put a little oil on it before you put it back on, that seems to work fine.
However the stock base gaskets stick to the cylinder too well and I have a feeling yours will get wrecked taking off the cylinder ( Nothing you can do about it because they are likely old since they are stuck on so well )
Gasket sets are cheap from treatland or 1977.
Here is a few, I dont think the 70cc gasket sets make any difference
honda hobbit 70cc gasket set
honda hobbit 50cc complete gasket set
Honda Hobbit Moped Gasket Kit
And for cleaning again, maybe little scraper/putty knife may work to get in between the fins, and some cheap wire brushes if you dont have a bench grinder. Tape off the mating surfaces with some masking tape if you use a rough wire brush.
Either that or just leave it, Its probably fine. (edited)
  Honda Express Cylinder Jug RemovalTopic by: Adam Kollipara Adam Kollipara 08/08/11 11:46PM
  Re: Honda Express Cylinder Jug RemovalRe: *.* HONDA *.* HONDA 08/09/11 05:33AM
  Re: Honda Express Cylinder Jug RemovalRe: Green Marauder Green Marauder 08/09/11 07:36AM
  Re: Honda Express Cylinder Jug RemovalRe: Green Marauder Green Marauder 08/09/11 08:25AM
  Re: Honda Express Cylinder Jug RemovalRe: K L K L 08/09/11 08:38AM
  Re: Honda Express Cylinder Jug RemovalRe: *.* HONDA *.* HONDA 08/09/11 01:00PM
  Re: Honda Express Cylinder Jug RemovalRe: *.* HONDA *.* HONDA 08/10/11 08:08PM
  Re: Honda Express Cylinder Jug RemovalRe: Adam Kollipara Adam Kollipara 08/09/11 03:20PM
  Re: Honda Express Cylinder Jug RemovalRe: Tim McGarvey Tim McGarvey 08/09/11 03:30PM
  Re: Honda Express Top End AssemblyRe: Adam Kollipara Adam Kollipara 08/30/11 10:04PM
  Re: Honda Express Top End AssemblyRe: Noah Reinhart Noah Reinhart 08/30/11 11:20PM
  Re: Honda Express Cylinder Jug RemovalRe: *.* HONDA *.* HONDA 08/31/11 02:56AM
  Re: Honda Express Cylinder Jug RemovalRe: Adam Kollipara Adam Kollipara 08/31/11 07:13PM
  Re: Honda Express Cylinder Jug RemovalRe: Glenn Kuehn Glenn Kuehn 09/05/11 02:27PM
  Re: Honda Express Cylinder Jug RemovalRe: Green Marauder Green Marauder 09/05/11 04:30PM
  Re: Honda Express Cylinder Jug RemovalRe: Abby King Abby King 03/01/19 03:16PM
  Re: Honda Express Cylinder Jug RemovalRe: Adam Kollipara Adam Kollipara 11/12/11 12:38PM
