Re: Honda Express Cylinder Jug Removal
Green Marauder /
Hey Adam, congrats on getting the jug off! That must have been a huge relief! I just took mine off again yesterday to check rings and reinstalled. What I do to put it back together is:
-Clean gasket surfaces. I use WD40 and a razor blade. Clean off oil.
-Attach gaskets in place with 4 tiny dabs of silicon on outside edge of bolt holes. This will keep them from sliding around when you are trying to line up and install everything later.
-Lube inside of cylinder and outside of piston and rings with 2-stroke oil.
-Make sure all surfaces are clean
-Insert piston into cylinder carefully, one ring at a time. I just use my thumbnails to press the ring into its slot so I can slide piston into cylinder. The piston only needs to go into the cylinder about half way.
-Hold cylinder up to the connecting rod with one hand, lining up holes in piston with hole in connecting rod.
-Insert wrist pin through cylinder and connecting rod with your 'free hand' (ha-ha! Got a match?)
-Once the wrist pin is in, I put a block of wood under the cylinder to support it so I can center the wrist pin and put the clips on the ends of the wrist pin that hold it in place.
-Put top two bolts through head, gasket, cylinder, gasket and finger tighten.
-Put in bottom two bolts and torque all four bolts working in an 'X' pattern.
Good luck to you!
  Honda Express Cylinder Jug RemovalTopic by: Adam Kollipara Adam Kollipara 08/08/11 11:46PM
  Re: Honda Express Cylinder Jug RemovalRe: *.* HONDA *.* HONDA 08/09/11 05:33AM
  Re: Honda Express Cylinder Jug RemovalRe: Green Marauder Green Marauder 08/09/11 07:36AM
  Re: Honda Express Cylinder Jug RemovalRe: Green Marauder Green Marauder 08/09/11 08:25AM
  Re: Honda Express Cylinder Jug RemovalRe: K L K L 08/09/11 08:38AM
  Re: Honda Express Cylinder Jug RemovalRe: *.* HONDA *.* HONDA 08/09/11 01:00PM
  Re: Honda Express Cylinder Jug RemovalRe: *.* HONDA *.* HONDA 08/10/11 08:08PM
  Re: Honda Express Cylinder Jug RemovalRe: Adam Kollipara Adam Kollipara 08/09/11 03:20PM
  Re: Honda Express Cylinder Jug RemovalRe: Tim McGarvey Tim McGarvey 08/09/11 03:30PM
  Re: Honda Express Top End AssemblyRe: Adam Kollipara Adam Kollipara 08/30/11 10:04PM
  Re: Honda Express Top End AssemblyRe: Noah Reinhart Noah Reinhart 08/30/11 11:20PM
  Re: Honda Express Cylinder Jug RemovalRe: *.* HONDA *.* HONDA 08/31/11 02:56AM
  Re: Honda Express Cylinder Jug RemovalRe: Adam Kollipara Adam Kollipara 08/31/11 07:13PM
  Re: Honda Express Cylinder Jug RemovalRe: Glenn Kuehn Glenn Kuehn 09/05/11 02:27PM
  Re: Honda Express Cylinder Jug RemovalRe: Green Marauder Green Marauder 09/05/11 04:30PM
  Re: Honda Express Cylinder Jug RemovalRe: Abby King Abby King 03/01/19 03:16PM
  Re: Honda Express Cylinder Jug RemovalRe: Adam Kollipara Adam Kollipara 11/12/11 12:38PM
