Re: Converting points to cdi, 80' honda express
Jack Rutherford /
Dredging here. I converted a '78 nc50 to CDI. I put the '78 engine on an '81 frame and took the '81 stator, flywheel and flywheel retaining ring and put them on the '78 engine. You need to transfer all of those items as the '78 flywheel and flywheel retaining ring won't work with the '81 stator. Timing will be way off. I, of course, used the Honda CDI that came with the '81 Express.
